1. fsiconcepts
  4. Wednesday, 25 April 2018
Hi!
I use the KINVARA template and like to change generally the positions of Logo and Hornav-Menu under header-layout setting ROW, that the Logo is on the right side and the Hornav-Menu on the left, so in reverse to the default setting.
The same need to be with the Slide-Out Menu and the Toggle. Menu and Toggle need to be positioned left and the Logo right.
Is that possible without creating a complete new template?
Thanks in advance.
To amend your logo position you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.logo {
order: 1;
Moving the mobile menu to the right is a little trickier. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will make this amendment for you. For our reference please paste a link to this post in your email.
