1. speerwolf
  3. Saturday, 21 September 2013
is it possible to make the Kindle background transparent? I mean, if you slide upwards, that only the content overlays the slideshow? I already tryed to insert rgba (0,0,0,0) in a new css-class and linked this one with the DIV of the background.
But that was no solution.
Any help?
Cheers
Presuming I understand you correctly you can try adding the following to the Custom CSS field of your templates parameters...
#body_bg {background: none !important;}
Thank you !!! Exactly what i was looking for :)
Hi.
I have another question:
Now there is a shadow going upwards when i´m scrolling (See Attachment).
I think it´s a gradient spanned from an css file? But i don´t find the code. Where can i delet this?
thanks alot.
Update:
I found out, that the shadow is only there, when the width of the slideshowmodule is set to 100%
To remove this shadow try also adding the following (you can combine it with your previous CSS if you wish)...
#body_bg {box-shadow: none;}
