1. skyd34th
  3. Tuesday, 25 August 2015
Is there the way to show top filler modules (circle photo - J51_ImageLinkHover) on mobile phone?
On pc and tablets is ok, on phone not visible
best regrads
Lucas
Hi Lucas
Would you have a URL to an example of your module?
You can check on kindle on your demo serwer
This modules is visble on phone only in horizontal mode, in vertical they dissaper.
best regards Lucas
Hi Lucas
Presuming you are using the demo installer may I suggest navigating to Extensions -> Template Manager -> [YourTemplateStyle] -> Responsive Options and in the 'Phone (Portrait) Custom CSS' field remove the following...
#container_top_modules, #sidecol_b, container_top3_modules {display:none;}
Great, thx
Now works, but this images in circles has bad proportions (squeezed from the top, like egg not circle)
best regards
Lucas
HI Lucas
i send you email
best regards
Lucas
