1. gabrielle
  3. Monday, 30 April 2018
For kindle I would like to be able to change the article, module in fact everything that's not in the header/footer to the same colour, can this be done simply?
  1. http://cctest2018.conradicreations.com/
What color would you like to change your entire background to?
Thank you for your resonse Ciaran, I have moved on ssince then and found a workaround, I do still have some issues
1) on the home page there a couple of alignment issues,
a) how can I centre the module titles
b) how can I contrain the text under the 3 bear images, ideally I would like the text to align with and be the same width as the images,
2) l would like to find away of putting my logo central in the same bar as the bottom nav and the copyright info, I would also like to be able to change the bar colour to the same as the colour under the site logo, hopefully that will also be reflected in the contact page which also has a large grey area
Hi Gabrielle
1.a. To amend you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.module .module_header h3 {
text-align: center;
1.b. To the same CSS field also add the following...
.contentbottom .custom {
padding: 0 40px;
2. I am not sure if I understand you correctly. Would you have an image detailing what you wish to achieve?
