1. Tompakidf2
  3. Friday, 18 September 2015
Hello guys,
I have just bought Vitality and installed it at http://www.taxinicosia.com
Do you know how to keep the menu to the top of the page like template Central on my other page http://www.athensairporttaxi.com/
Thanks a lot,
Ach
Hi Ach
Maybe try adding something like the following to the Custom CSS field of your templates parameters...
#container_hornav {
position: fixed;
#container_header {
padding-top: 55px;
Thank you Ciaran,
We would also like to remove the thick border below the logo area.
I have already removed it from the left and right sides using
#header_bg, .vegas-slide {
border-width: 1px !important;
I still can not find how to remove it from the bottom.
Thank you very much for all your help!
Regards,
Ach
To remove try adding the following to the Custom CSS field of your templates parameters...
.header-bottom-bar {
display: none;
1. Using Central, I try to make the top menu on mobile to stick always on top of the screen while scrolling ( (see http://athensairporttaxi.com/).
2. Using Vitality, I am a bit closer to achieving it. The bar sticks on top but the menu button does not stick (see http://weathercyprus.com/ )
Any suggestions?
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.slicknav_menu {
padding: 5px 0;
position: fixed;
width: 100%;
z-index: 120;
#container_spacer1 {
height: 60px;
position: relative;
2. To amend try adding the following to the Custom CSS field of your templates parameters...
.slicknav_menu {
position: fixed;
Many Thanks
