1. heart1010
  3. Monday, 09 July 2018
can you please have a look at one of my sites, https://www.wohnmobile-mindelheim.de
When you look at this site with mobile view (or make it small width on desktop) so the hamburger menu appears top right the hamburger should open with a click - everything alright when you are on the homepage/frontpage.
But then click here for example the "Mietanfrage" menu item and then test again click on these 3 lines from the hamburger menu, nothing happens!?
(also no error in chrome console :( )
Thank you very much!
Installing jQuery Easy to resolve the conflicts appears to have resolved the issue (https://www.joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy).
I am also having some problems with mobile display. The module backgrounds bleed over into other modules and the entire site does not resize when my Android phone is in portrait mode. With other templates, the modules are displayed one after another vertically when there is not enough room to display.
I looked at the responsive settings for the template but could not identify how to correct this.
Also the mobile menu is just barely visible. I made some custom css changes and I suppose I could work on the css more. Do you have a quicker solution?
Thanks,
Steve
  1. http://landauclients.com/silke/
Hi Steve
