1. picht
  4. Tuesday, 19 November 2019
I have the Kaylee template and when narrowing the width of the browser the website changes to a mobile version.
But not all the components change at the same width.
The menu changes at 1140 px and i have found the setting where I can change this.
But I have a J51_News module for some of the pages containing 2 or 4 articles. They change layout from showing side by side to one below the other before the menu changes to mobile version.
How do I change at what width they should change layout?
Picht
Hi Picht
Would you have a URL to an example of your News module?
Hi Picht
Here it is:
https://www.picht.dk/letridning_v2/
/Picht
Using the Custom CSS fields in the Responsive Options tab of your template settings, you can use the following CSS..
For 2 Columns in your news module...
.j51news225 .newsitem {
width: 50%;
For 3 Columns in your news module...
width: 33.3%;
For 4 Columns in your news module...
width: 25%;
Hope this helps.
Hope this helps.
I see no change after adding the text to the CSS field in the responsive tab.
See attached screenshot.
I also don't really understand what it should do.
On some pages I have 4 newsitems and on other pages 2 or 3 newsitems.
My problem is that I can't control when the newsitems go from Normal to tablet-mode. When does this happen? And why does it hapen before the menu goes from normal to tablet-mode?
Rgds
My apologies, I misunderstood your query. Your news module switches at 1280px wide. You can adjust the width your menu changes via the Genereal -> Responsive Options tab of your template settings (Mobile Menu Breakpoint).
Thanks.
Where/how can I change at which width the news module switches?
1280px seems a bit large, and I want it to switch to mobile at a smaller width.
/Picht
Hi Picht
You will need to create an override for your module. If you are not familiar with how this is done, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will create the override for you. For our reference please paste a link to this post in your email.
Hi Picht
Great, I tried and got it working. Thanks a lot :D
Great work... thank you for the update.
