are all templates ready for Joomla 5
Greetings Juergen
@webnechkt clearly your information is false. I'm not sure how you came to that conclusion
I see no reason why templates should have any issue with Joomla 5. Changes in Joomla 5 largely focus on removing depreciated code and namespacing with fields and xml which should have no bearing on the frontend at least. There is some frontend issues with namespacing but these should not be an issue once you have the Behaviour - Backward Compatibility plugin enabled. We will be resolving these issues in a future round of updates.
I've tested the templates mentioned here (Emani, Layla and Nina) with each templates demo content and I am unable to replicate any issues.
wicklert Is your issue present on all menu item types? Is the issue present with the default Joomla template? Is the issue present if you disable all modules and 3rd party plugins.
I really hate the way Joomla depends on version specific templates. After a miserable failed attempt to upgrade from Joomla 3 to 4 I do not even consider updating to Joomla 5.
I'd rather switch to another platform than going through all this hassle again.
