1. Forrest Gump
  4. Thursday, 30 November 2023
I have finally updated to Joomla 4 :) I did it as described here https://www.joomla51.com/forum/procedure-to-update-j51-joomla-3-templates-to-j51-joomla-4 by Ciaran; renamed the html folder to html-backup.
Then I updated to Joomla 4 and then updated the templates. The html folder was then also there. I then moved the files from the backup to the html folder and deleted the backup folder.
Except for the imagehover, everything works now. When I want to update imagehover, I get the error "JInstaller: :Install: The file “…/install_656857c711fd2/media/js” does not exist.“ - the extension doesn't work as expected either.
What can I do here?
Thank you!!!
I have sent you the access data by e-mail. Please let me know when you have looked at it.
Many thanks & best regards
thank you for your efforts. The error occurs again when installing imagehover.
On the contact page, the background is only displayed correctly for the first image (blue) and the background is transparent for the other contact images.
Sorry, but can you please take another look?
Or do I need a different version of imagehover?
Thanks & greetings
Does installing the latest ImageHover module from your Profile -> Extension Downloads resolve the issue? Template may not always be bundled with the latest version.
Thank you very much, it worked great. :D
Happy new year!
Great... thank you for the update and a happy new year top you and yours :)
