On this site I upgraded to Joomla 4: Title
Apparently the problem comes from the Ensley template
The error report is at Maximum
can you guide me
thanks in advance
Christian
The 500 error occurs on all menu links.
If I use the Nina template I don't have this error on menu links but J51_LayerSlideshow still doesn't work correctly
Could I ask you to try deleting your templates html folder (../templates/j51_ensley/html) and re-installing your template and see if that resolve the issue?
If not, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
500 error issue fixed
There remains the problem of the J51_LayerSlideshow module
I send you an email for an access to the administration
Christian
