I have run into the same problem when doing a fresh installation of J4 Nina v. 1.1.11 and I am running PHP 8.1. When I pulled back to PHP 8.0 one of my other websites built with J4 Nina 1.1.5 didn't work.
UPDATE: I just did some troubleshooting and was able to install the Nina 1.1.11 template only onto a Nina 1.1.5 installation running on PHP 8.1. No errors. The problem seems to be a fresh install with the J4 Nina 1.1.11 installation for me.
Strange. Just to check if this issue is related to the template or the demo installer could you try temporarily disabling the template overrides by renaming the template html folder to html_bak (..templates/j51_nina/html).
