1. ecweb
  4. Tuesday, 25 October 2022
When trying to update my site from Joomla 4.1.5 to joomla 4.2.3 I get a warning that I need to update j51_emani template.
Is this template compatible with Joomla 4.2.3? Has it recently been updated and do I need to install the updated version first?
Hello ecweb,
the current version of the j51_emani template is 1.1.7 from 22-Oct-2022.
It sometimes appears that Joomla asks for an J51 template update. You can normally ignore this.
Just keep the template updated if there is a new version on J51 available.
If you log in here to your profile you can find the current version in Profile > Template Dowmloads.
Pls keep in mind, that any changes to the template that are not made in custom.css or in an overwrite (in /templates/j51_xx/html/) will be overwritten if you update youre template.
A backup before update could be a good idea ;)
Hope this helps :)
Oliver
