1. mediafrog
  4. Saturday, 03 May 2014
Hi cirian,
are your templates ready for joomla 3.3.0? Yesterday I made an update to 3.3.0 (Resonate), and it doesn't work very well.
Hope you can answer me a.s.a.p.
Grit
Hi Grit
There should not be any issue using the Joomla 3.x version of the template with Joomla 3.3. Could you detail for me the issues you are having?
after the Update of Joomla 3.3.0 the slideshow-module is no longer working
paths are ok , rights as well as menu settings
thanks for help
Problem solved, was a problem with the access right to the pictures
Great! :)
Thank you for the update!
