1. pat02
  4. Monday, 26 November 2018
In Kinvara Template I noticed thate the Edge browser does not load Google fonts on first page load. In many cases reloading the page helps to load Gggole font.
I noticed that in inc/head.php there is no protocol:
echo '<link rel="stylesheet" type="text/css" href="//fonts.googleapis.com/css?family='.$v.':200,400,600&subset='.$font_subset.'" /> ';
So I did add https there. But it does not solve the problem.
Clear Cache and deleting Cookies does not help either.
Only happens with Edge (I use 42.17134.1.0.)
A friend can reproduce the problem as well using Edge.
Joomla is 3.9.
I will send you a link and Administrator Login by mail.
Thank you very much!
Patrick
Hi Patrick
Strangely we are unable to replicate this issue. The Lato font loads without issue on the first paint in MS Edge. Have you tried clearing your browser cache?
Note there is no need for a protocol when calling the google font. Adding one means the font will only load with the defined protocol (HTTPS).
Yes, Browser Cache cleared but the problem remains. The first page load loads the font correctly. But if you click on any subpage after, then the font gets lost and Times is loaded. Sometimes it happens after third click on any subpage.
Really strange...
I removed https form header.php, thanks for the hint.
Patrick
Hi Patrick
Unfortunately, we are still unable to replicate this issue. Using MS Edge and opening multiple menu items, the same fonts continuously load... https://gyazo.com/b668c33e73b69211c1bf0edd2f7629db
Very strange. After 2nd click it looks like this:
Thanks a lot for your support!
I'll investigate further (but have no clue at the moment...:o )
Patrick
