1. webbie
  4. Tuesday, 23 September 2014
Hallo ich habe im Template Grafik das Hauptmenü auf der hornav Position eingefügt.
Nun klappt aber das Untermenü leider nicht aus, obwohl ich im Modul alles entsprechend eingestellt habe.
Also Untemenüpunkte alle, erste Menüebene 1 und Submenu auf ja (Joomla 3.x).
Habe ich irgendetwas übersehen?
In der responsive Ansicht hingegen wird alles korrekt angezeigt ;-)
hello, so i try it again in english:
i use your template grafik and now i have the problem, that the submenu does not work in the hornav position.
so i made it as default in the template and at the modul position i made the following settings: first menu level:1, second level: all and allow submenu. but it still doesnt work. Does anyone have an idear, what i did wrong?
thank you so much!
that isnt possible yet, because it is not already online.
is there any other chance, to have a look or is there something i can tell you that will be helpfull?
It is hard to say as it could be a number of different things...
By default the hornav module position is not enabled. Have you enabled it via your templates parameters? Does your sub menu items appear in other module positions? Have you enabled 'Always show sub menu items'?
maybe my screenshot can help you?
you see there my homepage with the menu and under the item "diverses/links" there are several items which i can not see yet, when i come with the mouse over or click the buttom
thank you very much!
as i said, everything is fine, the right position in the module and template i think everything is alright!
maybe there is a conflict with the new joomla 3.3 or better now 3.4 version?
ok, so maybe you can tell me what that means?
Converting menu to a Module Position
When creating a menu module for the hornav module position ensure to add moomenu to the Menu Tag ID field of your modules parameters. This enables the animated dropdown menu as seen on our template demo.
does that mean i should take the word moomenu into the id in the modul?
ok, so i did and now it works fine!
Thank you for your help!
First i did not understand that , but i tried it and now its ok!
