1. rafal.holes
  3. Sunday, 16 April 2023
I'm having trouble loading java code on a multilingual site.
The base page loads correctly.
Java does not load after switching language. Module animations and the "back to top" button do not work.
Will you take a moment to check it out?
Thank you in advance.
I have just noticed that you have already sent access details. Could I ask you to allow us access to your extensions manager so we can update your template?
Yes of course. I'm prepared for it.
Everything is ok. Such a trifle, but so much research and analysis. Thank you and sorry for my inattention. As always, your help is invaluable. All the best.
Hi, can you please help?
Hi Rafal
Yes of course. You are now a super user
Thank you Rafal
Thank you Ciaran.
It's almost okay.
The script loads fine, but now there is no mobile menu on any page
Can you fix this remaining problem?
Thanks in advance.
Is it ok for us to install the latest download of the template to your Joomla installation? Any changes you have made to the core template files will be lost.
We are struggling to replicate this issue locally which has made it difficult for us to find a solution.
Thank you Rafel
OK the issue turned out to be rather simple in the end. In the Responsive Options tab of your template style settings, you will see an option to set the mobile menu (Select Mobile Menu). In each case this appears to have been set to a menu that was not available to the assigned menu items.
I have amended each of your 'start' template styles to the correct menu so your homepage should be now working correctly. You may need to check some of the other template styles for non homepage menu items.
