1. carolyn
  4. Thursday, 09 January 2020
I'm using the one-page website style, and have turned on the sticky menu header. However, in this mode when the page scrolls upwards, it falls behind the logo/menu section. I really want to keep the top menu in place; is there some way to fix this?
kottinstitute.org
Hi Carolyn
.is-sticky .logo {
padding: 0 30px 20px;
I don't see any change after adding the code.
Screenshot attached of the "Application Process" menu item. I'd like it to fall at the main headline for that section. Other sections are worse in that they cover the bulk of the copy for that section.
Maybe I misunderstand your query. You wish to just have the menu sticky, not the logo?
In the screenshot above, the menu link "Application Process" scrolls to fall into the 3 boxes, and doesn't hit the top of the headline "The Application Process" which is the top of the bottom-1 module where the menu link directs it. Basically, the menu links don't scroll to the TOP of each module section, which would be expected.
Ideally I'd like both the logo and the menu to be sticky.
Have you tried amending the Miscellaneous -> Scroll To Offset option in your template settings?
Thank you! That worked, though I had to give it a big -200 px to fall where I wanted it to.
