1. belex24
  4. Friday, 05 June 2020
Hi there, where can I change the gradient? My client likes just one color. Thank you
Thank you! Worked :) :)
Would you have a URL to an example of this gradiant?
sure; pls. have a look at your demo
https://www.joomla51.com/demo/0164/
Ah my apologies. I thought you were referring to the gradient in showcase image. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
#container_header::after {
background-image: none;
