1. ukfish1
  4. Thursday, 05 December 2019
Ref http://www.west5web-build.co.uk/contact
If you view the following page you will see there is a big gap above the logo/menu bar with the following price of code in it:
It is only on this page and I can;t figure out where its coming from. Are you able to help at all?
Thanks. Paul
yes thanks. I used a module instead of the plugin code and it seems OK
Paul
You use a Contactform.
Add CSS or disable the Contactform.
.creativecontactform_wrapper_inner {
display: none;
I can't disable the contact form as I need to use it. Anyway, there is another contact form using the same component at http://www.west5web-build.co.uk/support-us and that displays OK
Paul;
Hi Paul
Have you since been able to find a solution to this issue? We currently are unable to notice any space at the URL provided (FIrefox - http://www.west5web-build.co.uk/contact).
