1. davec62
  4. Tuesday, 25 June 2024
I had the same problem abut 2 years ago with the Layla Template. The same is now happening with the Natalie Template. It doesn't appear the actual solution was posted on the Layla post. It may have been that the template was updated ;)
Uncaught ReferenceError: jarallax is not defined
I would appreciate it if this can be fixed please?
David
Franc
Hi David
thanks for the fixing this. Can you tell me what is required going forward in case I encounter the issue again?
Dave :)
could you do that also for Naomi as i'm getting the same error
HI David / Franc
This fix is now available on the latest download of both our Layla and Naomi template.
