1. Hammur
  4. Friday, 07 November 2014
Hi. recently noticed a bug with the tooltip in the PianoForte template to "Edit article" on frontend.
There are some <br/> tags which doesn't seem to function, so it looks kinda weird.
When you mouse over the "Edit article" icon when logged in, you'll see the following tooltip
Edit article
Published <br /> dd/mm
YYYY <br /> Author name
There is a "space" between 'r' and the '/', not sure if that is what causing this?
How can this be fixed?
See attached screenshot.
Is the same issue present when you use one of the default Joomla templates?
Hello Ciaran. I just tested that by switching over to protostar template and it seemed to be the same there.
So I see now that this is probably not a template issue.
Will have to figure out what then is causing it.
