1. pat02
  4. Wednesday, 29 August 2018
With your J51news module I display articles in two columns. Works fine.
Unfortunately the articles have a gap because the articles are not all of the same height. Please see attached picture.
Is it possible to remove this gap (masonry layout)?
If I set the columns to 1 in module parameter and add following CSS:
.j51news .j51news_inside {
column-count: 2;
column-gap: 0.9em;
.j51news .newsitem {
display: inline-block;
margin: 0 0 1em;
padding: 0 !important;
width: 100%;
I get two nice columns without gap. But the article sort order is wrong. The News are sorted
1 | 4
2 | 5
3 | 6
instead of
1 | 2
3 | 4
5 | 6
So this CSS can't be used.
Is there a way to make your module to list aticles of different height nicely without gap?
Thank you very much!
Patrick
Hi Patrick
Would you have a URL to an example of your news module?
Information just sent by email.
Thanks a lot!
Patrick
Thank you Patrick
I now understand your issue. Unfortunately, the column-count property is limited regarding item ordering (as you have pointed out). The only way around this is to use javascript to set the positioning (eg. https://masonry.desandro.com/).
If you can bare with me a few days, I will look into adding the masonry script to the news module.
Yes, of course. Thanks a lot!
Patrick
Hi Patrick
May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will make this amendment for you. For our reference please paste a link to this post in your email.
Mail sent.
Patrick
Thank you Patrick
The masonry script has been added to your news module as requested.
Hi Ciaran and thanks a lot!
Looks great!
Will do testing and let you know the results.
Have a nice weekend.
Patrick
Note the count-column CSS has been removed. Your module should now respect the column settings in your module settings.
Enjoy the weekend!
Everything works fine now.
Thank you very much for your great help!
Best regards
Patrick
