I use the new Central template together with j51-carousel extension. But the carousel extension does not work properly when it is placed in Contentbottom-A position and simultaneously another module (for example Custom HTML) is placed in the Sidecol-B position on the right side.
The carousel setting is 1 column per slide, but you will see a second column with a part of the next slide as a overlay in the Sidecol-B position and some letters of this next slide on the left side of the carousel module position (see attached screenshot). In the other module positions the j51-carousel extension works perfect.
Do you have a solution for me to solve this problem?
Many thanks and Best Regards ...
Volker
