1. crimle
  4. Tuesday, 06 December 2022
I just bought J51_Valencia_J4 and tried to install it. I am encountering this error
«Downgrade from version 1.1 to 1.0.0 not allowed».
Thank you and kind regards
Chris
A possibility. Did you accidentally/accidentally buy the J3 version of the template?
Do you want to update J3 template to J4 template?
I think Ciaran needs more info...
I am quite sure it's the J4 version of the template. I had been upgrading the website from J3 to J4. After having done this successfully, I tried to install J51_Valencia_J4, hoping to replace the existing J51_Valencia_J3. But then, installing J51_Valencia_J4 failed with the error message
I helped myself by uninstalling J51_Valencia_J3 first. After doing so, I could install J51_Valencia_J4 without any further issue. For me this issue is resolved. But I think Ciaran should have a look at the version numbers. I don't think that a downgrade error messege should occur when you upgrade :-)
Kind regards
Chris
Hi Chris
