1. MarcioD
  3. Wednesday, 25 September 2024
I'm using "J51_ThumbsGallery", how can I change the terrible quality of the thumbnails?
I can improve the module code if you tell me what to do :)
Fantastic, thank you very, very much :)
Would you have a URL to an example of your image?
The module uses the PHP ImageCopyResampled function (https://www.php.net/manual/en/function.imagecopyresampled.php) to resize the image. As long as the original image is larger than the thumbnail, there should be no difference in quality.
  3. # 3
You might find that increasing the size in your module settings and adding the following to the custom CSS field of your template settings might help...
.j51thumbs .j51Box img {
max-width: 160px;
This will create higher resolution images but force the current size with CSS.
  3. # 4
Thank you very much, now it's wonderful :)
  3. # 5
Only now when you hover the mouse over it the shadow is moved.
  3. # 6
To amend try also adding the following to the Custom CSS....
.j51thumbs i {
transform: scale(.5);
transform-origin: 0 0;
  3. # 7
