  1. svenwittenzellner
  3. Saturday, 06 April 2024
Hello :-)
I have recognized an issue with the module mod_j51imagehover:
PHP Version 8.2
Joomla 4.4.3
Please have a look:
https://www.spvgg-stephansposching.de/index.php/verein/vorstaende
Happy to hear from you soon.
Best, Sven
Yes indeed, thanks for your help.
Have a nice evening :-)
Which version of the imagehover module are you using?
Have you ever deleted it and reinstalled it?
Since when did the error occur? (Did you change anything?)
Which version of the imagehover module are you using? >>> Imagehover module version 2.1.3
Have you ever deleted it and reinstalled it? >>> Yes, no changes at all
Since when did the error occur? (Did you change anything?) >>> before not in place, first draft
I can give you access to the website ;-)
define the issue.
does going to the style page of the module change anything?
I define different options(e.g. color), but no change at all in the front-end
Position is TOP1A, perhaps thats a issue?
I have the same version of the module. I was playing around. Everything works as it should.
Do you have the opportunity to install the module from another J51_Template template?
Unfortunately I cannot access stella and therefore cannot test it... The module in stella could possibly be defective...
the position probably has nothing to do with it
By the way, in my downloads you can download 2.1.4. But the fix has nothing to do with it, I think
Where can I download the Version 2.1.4?
I sent you an email with the needed information.
Best, Sven
Hi Sven
We do not appear to have received any access details related to this item. Could I ask you to resend your details. For our reference please paste a link to this post in your email.
Next try :-):D
Thank you :)
This issue should be now resolved?
