1. crimle
  4. Monday, 18 April 2022
with J51_Stella_J4 V1.0.0 the fontawesome icons are not displayed correctly. I am using the new syntax
<i class="fa-solid fa-phone"></i>
I think we had this issue before with other templates.
Thank you and kind regards
Chris
Hi Chris
I have just released an update for the Joomla 4 Stella template which should resolve this issue for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
If the issue persists after updating, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
with J51_Stella_J4 V1.0.1 the fontawesome issue is not resolved. I am going to send you the credentials to the website concerned.
Chris
Thank you Chris
There were a couple of small FA5 class errors in your article which I have amended (fa-solid instead of fas, fa-brand instead of fab). Your icons should be now displaying correctly.
Thank you Chris
I am desperate since I copied the syntax from here: https://www.joomla51.com/demo/0163/index.php/features/font-awesome
This is the URL provided on the J51_Stella_J4 demo website https://www.joomla51.com/demo/0163/index.php/features/font-awesome
There we find
<i class="fa fa-phone" ...
Chris
Hi Chris
For future reference, as Joomla 4 is loading FontAwesome 5, use the classes described here... https://fontawesome.com/v5/search
