the mobile menu in template Stella has the problem that menu items which have sub-items are not choosebale. Tapping on it opens the submenu not the item which is assigned to the menu-position. I of course understand that you had to mad a dicision which action follows the tapping.
In (e.g.) J51-Riley you solved that problem in a good way!
Now my question:
Is there a way to implement that funcitionality of the mobile menu of Riley into Stella?
I bought both templates, so maybe I could copy some code from Riley to Stella... - so far my simple idea...
Hope you can help.
Best regards,
Thomas
