1. DiabloV
  4. Tuesday, 03 December 2013
hello.
I just had all these errors, without any change in my site. (http://gite-du-weinbaum.com/)
I'm in firefox 25
This works perfectly on against by IE11.
joomla 2.5.16
Strict Standards: Only variables should be assigned by reference in /homez.726/giteduwe/www/plugins/system/jcemediabox/jcemediabox.php on line 331
Strict Standards: Only variables should be assigned by reference in /homez.726/giteduwe/www/plugins/system/jcemediabox/jcemediabox.php on line 136
Strict Standards: Non-static method JSite::getMenu() should not be called statically, assuming $this from incompatible context in /homez.726/giteduwe/www/templates/j51_specialize/php/variables.php on line 8
Strict Standards: Non-static method JApplication::getMenu() should not be called statically, assuming $this from incompatible context in /homez.726/giteduwe/www/includes/application.php on line 539
Strict Standards: Only variables should be assigned by reference in /homez.726/giteduwe/www/templates/j51_specialize/php/variables.php on line 8
Strict Standards: Only variables should be assigned by reference in /homez.726/giteduwe/www/templates/j51_specialize/php/variables.php on line 9
Warning: Creating default object from empty value in /homez.726/giteduwe/www/modules/mod_j51thumbsgallery/helper.php on line 24
Strict Standards: Declaration of JCacheControllerView::get() should be compatible with JCacheController::get($id, $group = NULL) in /homez.726/giteduwe/www/libraries/joomla/cache/controller/view.php on line 0
A priori, I no longer have the problem.
Strange.
Is left like that.
If ever the problem reappeared, I would do you an email as you suggested.
thank you
