1. joomlagal
  3. Sunday, 26 May 2019
J51 Sophia Customization
I have 3 modules that I would like to use. I would like the modules to show their title. When I view the modules, a small horizontal line is indicated under the Module Title. (Modules 2a, 2b and 2c)
Is it possible to remove the horizontal line underneath the Module Titles? OR increase the size of the horizontal line to 100%
Thanks for any help you can provide.
To remove the under line you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.module .module_header h3::after {
display: none;
To increase the line width to 100% you can add the following instead...
width: 100%;
