1. crimle
  4. Wednesday, 09 July 2025
in my opinion, the icon «Passkey» is far too large. See screenshot. I even went so far as to completely hide it. The text link is completely sufficient.
#Passkey {
display: none;
Just a suggestion for future template improvements...
Kind regards
Chris
Hi Chris
The size of your pass key appears to be incorrect. Would you have a URL to an example of your login? No need to remove your solution as we can disable via dev tools.
the URL is in the designated field now.
Thank you and kind regards
Chris
  1. https://frauen-fokus.ch/downloads/login-fuer-seminar-downloads
Thank you Chris
This appears to be an issue with the template however until an update is release, you can try using the following CSS instead (assuming you wish to keep the icon)..
#Passkey {
max-width: 1rem;
Thank you Ciaran.
Kind regards
Chris
