1. crimle
  4. Saturday, 05 July 2025
I am logged in to the Front-End. I edit a module, set Status = Trash, then click [Save & Close]. The module is being saved, but it remains open. It closes when I click once more.
Thank you and kind regards
Chris
Hi Chris
I'm not completely sure that this effect is caused by the template.
  • Can you provide the URL and the Joomla version?
  • Can you try the operation with the Cassiopeia template?
Rolf
Thank you for your reaction. This issue can no longer be reproduced for some unknown reason.
Kind regards
Chris
I did a test on a (more or less) fresh J5.3.1 install and could not reproduce the issue either.
