1. pat02
  4. Wednesday, 30 December 2020
The news module j51_news shows all items in a row and on whole screen. Please see screenshot. I did set all parameter the same as in your demo installation.
So it should display 3 news only and max. content width (bottom-2a).
I have removed my custom.css to be sure it does not cause the problem and I updated the module to its latest version 3.0.10.
I use Joomla 3.9.23 and PHP 7.4.13
Any idea what goes wrong?
Thanks a lot.
Patrick
Hi there
I checked it with the same template on the same position, I'm fine. however, expansion version 3.0.0
I added the settings from my news module here ... Differences to yours?
Hi and thanks.
I use almost same setting. But instead of "Overlay" I use "Column image/text". I did try "Overlay" but it does not solve the problem.
I think it must be PHP problem or JS problem. As you can see from my screenshot the module even does triple the articles. And it displays "slide 6 to 8 of 6". But I have 6 slides set up only. And set 3 columns to display at once.
Here is a better screenshot to show the issue:
As you can see there, the module is messed up.
Hi Patrick
Happy New Year and email is sent :)
Thanks a lot.
Patrick
