1. ungerank_com
  3. Friday, 26 September 2014
I would like to insert the Ajax_search module for Jomres in the sidecol-b positon, but this error message is showing
"pat-Error You have an error in your template "date_rows", which leads to recursion".
Could there be a problem with the Resonate Template?
Thanx
Great to hear and thank you for sharing your solution :) :)
Now it works ! :woohoo:
The solution was so simple - only change Bootstrap2 to Bootstrap3 in jomres.
That`s it.
Thank you for the update and best of luck in finding a solution :)
Hello Ciarán
I have tryed it, and yes it is present on all default joomla templates.
The Resonate template is not the Problem, it must be something wrong with the jomres code.
Thank`s a lot .
Is the issue present when using one of the default Joomla templates (beez)?
