1. cmel
  3. Thursday, 05 March 2015
Hi, I had someone create my site for me and they are long gone. While I have moderate experience with Joomla and your templates I am having trouble formatting new pages that I need to add to match the rest of the site.
The main page in the showcase at the top uses Nivo-Szaki Slider, as do all the other pages. Only the home page is set to be a 100% width and appears to be xxx height (which I believe is the template default). All the other pages are 100% width and 170px height which I would like to replicate on the new pages.
Below are examples of the pages and difference in "header/showcase" heights and the page that has the extra space that I need to remove/reduce.
Brilliant! That fixed it. It was in the Menu Template items.
Thank you for your help.
Best Regards,
Cmel
Create a new slideshow, then the problem should be solved :woohoo:
Hmm, it matches the homepage so it might be the menu item settings. Go to Menus -> Main Menu and check what the other pages (ie: Bridal, Spa) have set here and see if it's the same for the Photos item:
http://i.imgur.com/7smyG6n.jpg
Can you provide a link to your site?
