1. margerone
  3. Wednesday, 20 November 2013
Hi admins, i need help, i've bought oxygen template and when i put online the site, ONLY the home page have a big problem,
it seems that don't load images and does not show nothing, but if i put the site off line, and then i go to site to see the results and it's all perfect.
May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email and also indicate the menu item in which you wish to split your articles.
Have any idea about the problem?
Have you since amended this issue as your images appear to be now loading fine on all pages when online?
the problem persist =( the slider don't work, the twitter widget don't shows, in "catalogo" section the custom search don't work, but if i put the site offline all works fine.
Please i have no idea what is working wrong.
what is the difference betwen offline mode and online mode?
i still need help.
Thanks a lot
I've Found the problem!!!
it's seems to be a problem with ZT TOOLS plugin, i've deactivated it and all it's working.
Thanks for ur time!
Nice work and thank you for the update!! :)
How do you edit the template so the articles come out spaced and margin's normal? Mine are all single lined and it causes the sentences to be bunched together. Here is my site: http://www.saintpatrickkcks.com/
I know how to edit. I just need to know where. I have looked at all the different sections and just am lost.
Presuming I understand your correctly try adding the following to the Custom CSS field of your templates parameters where 1.8em is your new line height..
p {
line-height: 1.8em !important;
For the benefit of other forum users please create new posts for new queries.
