1. eumel7
  4. Tuesday, 13 December 2022
I installed the J51 numbers module from the Bianca J4 template on a J4 website. It is the module version 1.0.4
I noticed that the animation of the numbers doesn't work. Tested on two different domains.
If I take the numbers module from the J4 template Layla, there is still the numbers module version 1.0.3 !! the animation of the numbers still works!
It doesn't work with version 1.0.2 either (no animation)
Link: (template bianca with numbers modul version 1.0.2)
https://www.dynamofanclub-sayda.de/index.php/interaktiv/bilderdatenbank
edit: The settings in the module are unchanged or always the same
Update: The numbers module from my extension download from j51 homepage does not have the problem. It is working. It works for Riley and Layla too. It's just the numbers module that comes with the "Bianca" template
Thank you for bringing this to our attention. I have just updated the Bianca template bundle to include the NUmber module inline with our Riley and Layla templates.
Hello Ciaran.
I would like to apologize. I have now deleted everything and reinstalled. The memory error no longer occurs! I do not know why.
However, it remains the case that the Numbers module 1.0.2 is not animated in the Bianca Template J3 template download!
I have now tried the Riley J3 (also 1.0.2). Now it works again. I can not explain it!
Can you please update the bianca template again in your templates?
further intervention for this error on my side is not
more needed!!
THANK YOU
I tested it with Layla and bianca. An update is made but you can no longer change the module because every save in the BE shows an error. In my pages you can only save 1.0.2 and the animation doesn't work there.
Do I update the extension, no matter from which package to 1.0.3 or 1.0.4 (which I own), by the way also from the J51 extension downloads here on the website, then the memory error occurs!
The error also occurs when I reinstall the module
Error code: An error has occurred!
0 Joomla\CMS\Form\Form::validateField() rule `CssIdentifier` missing.
Thank you for the update!
I have just re-updated the Bianca template with the correct Numbers modules. Hopefully, all should be now ok! :)
Thanks! Is working
(Only the description in the channglog.txt in the module data is still on 1.0.1)
