1. amo
  4. Tuesday, 15 February 2022
Hi, I just purchased the new Nina template and added, next to the main menu, another menu in the hornav over a module. In smaller size the hamburger menu for the main menu does not appear, and the menulinks of the hornav are not responsive.
Why?
Is there a possibility to add a menu with all the links of all the menues, which is shown in responsive mode in a hamburger menu?
Thanks. amo
Hi Amo
I am not sure if I understand you correctly. Would you have a URL to an example of your issue?
hi ciaran
i'd like to send you the link in a personal message - how do i do that?
amo
HI Amo
Details can be sent to [email protected]. For our reference please paste a link to this post in your email.
Actually I'm talking about the topmenu, which is not responsive, not the hornav position....
Thank you.
in addition I have a problem to add a menu in any modul position. I can add plain text or anything on for example top-1a, but a menu is not being displayed.
I believe I understand your issue. Only items in the hornav menu are placed behind a hamburger toggle on smaller screen devices. Unfortunately, this is by design and is a limitation of the template. All other menus will be displayed as they are on desktop.
A possible workaround may be to use a 3rd party menu module. I believe there is some available that will be replaced by a toggle button on smaller screens... https://extensions.joomla.org/category/structure-a-navigation/menu-systems/
