NINA joomla 4 version Using the supplied "Enhanced" Joomla 4 J51_news module the article urls are NOT SEO-friendly
same global configuration settings give perfect SEO-Friendly URLs when accessing same article via a menu or blog_post
I also have the problem with the current Joomla 5 version that the URLs are not NOT SEO-friendly.
With a hidden menu I was able to make the urls SEO friendly, but I would like to ask if there is an easier way to do this.
I have not yet created a separate hidden menu entry for a post so that you can see where the problem is.
thank you for pointing this out, but I had already posted it. The search engine friendly links work everywhere, only in News it shows the long URLs.
As mentioned, I was only able to fix this with a hidden menu.
It would be great if there was a simpler solution.
