I'm new with Natalie Template and while working on our new webpage some issues came up now I'm asking what I'm doing wrong or is there an issue with the template?
The Joomla 4.2.9 is set up new and I'm using J51_Natalie J4 Version 1.1.5 downloaded 28.03.2023.
1. When I activate J51_LayerSlideshow on Modulposition Showcase-1-a the Header is not sticky. If LayerSlideshow is deactivated the Header is sticky.
2. Modul Position Showcase-1a exists twice. see screenshot.
3. The Hornav Menu is not aligned as in the Exsample on left side it is right side.
4. In the J51_News Modul I can't set the Image Size. If I reduce the Value to e.g. 25 % is no reaction. see screenshot
5. I can't set the Numbers Color in the J51_Numbers Modul. The Modul uses ever the primary color of the Template Syle. see screenshot
Tell me what I'm doing wrong, please or does it look like an issue within the template or the template installation?
....and at my last I want ask how to create a Blog Page looks like the sample Blog of the Natalie-Blog-Examplepage. 3 Collums, comined pictures and articels,
Stefan
- Sbocki
- Saturday, 01 April 2023
Hi Stefan
Thank you Stefan
1. Disabling the 'Overlap Header if in showcase-1# module position' option of your LayerSlideshow module settings resolveds this issue.
2. It seems that the 2nd position is a duplicate in your database. Positions can be entered in to the database by typing directly in to your module positions fields. You could remove this duplicate however it should not cause you any issues. Both entries are the same position.
3. Is this still an issue for you? Your menu appears to be aligned to the left.
4. / 5. Could I ask you to allow us access to your extensions manager and I will examine this issue futher.
thank you for helping me.
1./2. Thanks for resolving this.
3. Is still not an issue for me. I found a solution (entry in custom css) in this forum.
4./ 5. Feel free to access to the extensions manager, do you need any further rights?
Stefan
Stefan
Hi Stefan
4./5. Yes, it appears we would need further rights. Currently, the Extensions Manager is not available to us with the details provided.
now I have set you to super user
access, so you should have access to the extension manger.
System-> Erweiterungen
Stefan
Stefan
Thank you Stefan
Your News and Number modules should be now displaying correctly.
the modules work as expected.
Thank you.
May I ask what caused the issue within the modules? Joomla, my settings/pictures or something inside the module?
Stefan
Thank you.
Stefan
Hi Stefan
For each module we installed the latest download which appears to have resolved the issue.
- # 9
Hi Cirian,
I tought I got the last version of the modules. Whatever, it works so have many thanks for your help.
I'll start my designing work now and I'm sure that we will definitely meet again.
Stefan
Stefan
- # 10
