1. pat02
  4. Tuesday, 25 July 2023
I use J51_Carousel on homepage. But within a certain area scrolling/swiping is not possible on mobile devices. Please see screenshot for details.
I use Joomla 4.3.3 and latest version of Nadia template and latest version of J51_Carousel. I have disabled custom.css. Still, the issue is there.
Can you please check this?
I can send you URL and login for a test environment if needed.
Thanks a lot.
Patrick
It works.
Thanks a lot.
Hi Patrick
.owl-carousel {
pointer-events: none;
Please install your J4 Demo installer.
You will be able to reproduce the issue.
Thanks.
Patrick
