1. Thomash86
  4. Thursday, 27 June 2013
hello
my homepage is smo-wien.at
i want to make the bacground from Firmenname SZS tranparent.
is it anyway possible?
Also I want that the black bar from the bottom of the page is away?
Thanks a lot!
thomas
Hi Thomas
Sure.. try adding the following to the Custom CSS field of your templates parameters....
#logo {
background: none;
box-shadow: none;
To remove the footer area try also adding the following...
#container_base {
display: none;
perfect!!! its working! thanks thanks thanks
is it also possible that the main box from the site is also tranparent??
Presuming I understand you correctly try also also adding the following to the Custom CSS field of your templates parameters...
.module .j51imagelinkhover .j51button a, .module_style-box .j51imagelinkhover .j51button a, #container_main .wrapper960, #container_spacer1 .wrapper960, #container_bottom_modules .wrapper960, #hornav li > a:hover, #hornav li.active > a, #container_spacer2 .wrapper960, #container_hornav_mobile .wrapper960, #container_top3_modules .wrapper960, #container_slideshow_modules .wrapper960, #container_slideshow .wrapper960, #container_top_modules .wrapper960, #container_spacer2.container .wrapper960, .maincontent, #bottom_modules.block_holder, #top_modules.block_holder, #wrapper_top-3 {
background: none repeat scroll 0 0 transparent !important;
border: medium none;
box-shadow: none;
hello
thanks, but i want that th white background from the box is transparent
greetings
Sorry to say this is not possible as to be transparent the surrounding div (border) also has to be made transparent.
No Problem.. i think its better when this box is not transparent, otherwhise you cant read the text ;)
BUT why i have at the bottom a white bar and not normal background picture
The is due to your site content not exceeding the height of your browser window. To amend try adding the following to your Custom CSS field which will move your background image to the body.
body {
background-attachment: fixed !important;
background-clip: border-box !important;
background-color: transparent !important;
background-image: url("../images/IMG_1122neu.jpg") !important;
background-origin: padding-box !important;
background-position: 50% 0 !important;
background-repeat: no-repeat !important;
background-size: cover;
#body_bg {
thanks for your help!
at the dropdown menu the bachgroundpicture is going away. why? On each other menu its available
http://szabo.co.at.dd32122.kasserver.com/
Try replacing the added CSS to the following...
body {
background-image: url("http://szabo.co.at.dd32122.kasserver.com/images/IMG_1122neu.jpg") !important;
#body_bg {
