1. squazy
  3. Friday, 06 July 2018
Hi I can't get template overrides to work for J51_Maya. Is there something I need to set on it for them to work?
Simply creating the override should be all you need to do. Have you checked the /html folder of your template? Does the override exist? Which component/module are you trying to override?
