Hallo,
I installed a new Joomla 3.8.6 and activate the Search Module and the Login Modul. Everything was working. Then I installed the J51 Maya Tempate. Since this momente Search Module and Login Module doesn't work.
0 - Call to a member function get() on null
Joomla 3.8.6
PHP 7.2.6
What can IK do?
Many greetings
Heri Vielsäcker
- Heri.V
- Thursday, 29 March 2018
Hi Heri
Hallo Support-Team,
I installed a new Joomla and J51 Maya Template.
Adresse: http://www.hv-events.de
Language: german (from jgerman.de)
User: REMOVED
Passwort: REMOVED
Type: Superadmin
It's only a test website so you can change what ever you want.
Greetings
Heri Vielsäcker
User: REMOVED
Passwort: REMOVED
Type: Superadmin
Greetings
Heri Vielsäcker
Same Problem with the english version of joomla 3.8.6:
Adresse: test.hv-events.de
User: REMOVED
Passwort: REMOVED
User: REMOVED
Passwort: REMOVED
Thank you Heri
Updating the Maya template to each of your Joomla installations to the latest download has resolved the issue. This latest download can be obtained from your Joomla 'My Downloads'.
Dear Support Team,
many thanks for your very good and fast support.
I have one more question.
In your demo you show the submenues in 3 columns. On my website all submenues are in one column. How can I change to 3 columns?
Best regards
Heri Vielsäcker
Best regards
Heri Vielsäcker
Hi Heri
May I suggest the following article on this query... https://www.joomla51.com/tutorials/item/creating-multi-column-dropdown-menus
Hallo Claran,
thank you for your information. It's working now but i have some problems. When I use more then none submenue it's not working. The upper submenue calculate width and hight of the lower submenue.
Also with 3 columns the sub menus are going far beyond the scope and clip over the end of the landscape. Is there a way to prevent that so it always stays inside the page or have the ability to configurate the alignment (left/right).
Thank you you in advanced.
Best regards
Heri
Best regards
Heri
Hi Heri
To switch the menu dropdown to appear right aligned you can use the following custom CSS where 389 is the ID of your parent menu item...
Would you have a screenshot of your other issue? I am not sure if I understand you correctly.
.item-389 > ul {
right: 0 !important;
left: auto !important;
Hallo Ciarán,
I sorry that I clould not answser such a long time.
With your css it's working now. But I have one mehr question. On the screenshot you can see my problem. The dropdown is working until submenue 4. From submenu 5 no new row will opened. The submenu 5 will shown directly under submenu 4.
Is it possible to show all submenues directly under the mainmenue? On the second foto you the an exapmle from another template.
Many thanks in advanced.
Heri
Heri
- # 9
One option is to place all your menu items on the second level and to use the multi column option detailed in the following article... https://www.joomla51.com/tutorials/item/creating-multi-column-dropdown-menus
- # 10
this function you showed me before and it's very good working with one submenue level. But with more levels it's not working. See the screenshot. This menu has 3 levels of submenus but it's only possible to see the first submenu level. How can I show submenu level 1,2 and 3 in one submenue? See screenshot 2.
Heri
Heri
- # 11
By default this option is not available. You could try the following CSS which should come close to what you wish to achieve...
.hornav > ul > li > ul > li > ul {
position: relative;
opacity: .7;
visibility: visible;
left: 0 !important;
padding-left: 0 !important;
box-shadow: none;
- # 12
it's working now.
Thank you for your very very good support.
Best regards
Heri
it's working now.
Best regards
Heri
- # 13
