1. crimle
  4. Monday, 22 March 2021
Dear Ciaran
On my website I would like to use a content spoiler plugin that I found on JED. My website is on J51_Maya.
This is the spoiler code that I have to add to the article:
{spoiler}Add text here{/spoiler}
As soon as I add the spoiler code to an article, the font settings that are defined in the template are no longer respected. Example:
The settings for Template J51_Maya > Typography Styling are:
«Body Font Size» = «Large»
«Body font» = «Open Sans»
This works fine for articles that do not contain a spoiler.
On the other hand, articles that contain a spoiler have a different typography styling:
«Body Font Size» = «14px»
«Body font» = «Helvetica Neue", Helvetica, Arial, sans-serif»
In other words:
Instead of using Inline:22 the stylesheet nexus.css:231 is applied.
The issue seems to be template-related.
I tried with J51_Layla, which is a pretty new template.
With J51_Layla the spoiler plugin works as expected.
Thank you and kind regards
Chris
this resolves the issue. But nevertheless: J51_Maya seems to handle inline CSS in a different way compared with J51_Layla.
With J51_Layla the spoiler plugin works as expected (without adding anything to the Custom CSS field of the template).
Chris
Hi Chris
Would you have URL to an example of this issue?
The page without spoiler: https://playground.rimle.ch/
Font is «Open sans» 17px from Inline:3
The page with spoiler: https://playground.rimle.ch/spoiler-j51-maya
Font is «Helvetica Neue, Helvetica, Arial, sans-serif» 17px from nexus.css:231
Chris
Thank you Chris
Strangely you extension appears to partially remove inline CSS used to load settings styles. Does adding the following to the Custom CSS field of your template settings resolve the issue?
body, .hornav ul ul, .hornav ul ul a {
color: #383838;
font-family: 'Open Sans';
font-size: 17px;
