1. nebuladesigns
  4. Thursday, 20 November 2014
Hi There
I have entered my social media details in template settings but its not showing up.
Can you please take a look at http://www.nebuladesigns.co.za/NEW
Kind Regards
Tested using Firebug and modified the Right Padding by 20px and it is showing up.
Great :)... thank you for the update.
Obviously a template issue which we will look in to.
Hi There
My new site has been built using the Joomla 3.0 template instead and is due to launch later. Could you please take a look as my social media icons placeholders are appearing but not the actual icons itself. They only appear on some pages:
http://nebuladesigns.co.za/N3/
(note the sub directory)
I can grant you temp. access to the site backend. :)
It appears your FontAwesome icon set is not loading. May I ask is it enabled within the templates parameters (under styling tab)?
Thank you that seemed to work!
