1. freddy2311
  3. Friday, 30 August 2013
Hello.
How can I change the Links in the Single contact / Link, since I can find the place where I can change it.
thanks
You will find these links in your Contact settings. From your Joomla administration navigate to Components -> Contacts -> Contacts -> [YourContact] -> Display Options.
I will put my question here in since the title is general.
Can you help me with CSS. I have an article and above the article I've put a gallery. If I use contenttop position it looks ok but I would like tu put it in top1a, because it looks better when its delimited with shadow-border, however it does not expand to right height and thumbnails are half visible.
Hopefully you understand what I wrote :)
I've added a screenshot.
Well the page is not yet published. I can give you temporary access.
Temporary access can be sent to info@joomla51.com. Please paste a link to this post in your email for our reference.
The issue appears to be only present in the Chrome browser. Could I ask you to allow us access to your Extension Manager so we can change the core template files to try and amend the issue.
I've given you manager rights. Will I have to update the downloaded template or. better question can I? And will all template versions be updated?
We're unable to update access your Extension Manager so we have emailed you an updated version of the template which should hopefully amend this issue for you.
Thank you Ciarán
Here is the link
http://46.252.32.74/~publimar/univershotel/
and the text I am talking about is the following:
"Enjoy the comfort and quality services of our hotel."
Template was OK but when I changed text, it goes to the left instead of center.
The code is correct:
<h2 style="text-align: center;">Enjoy the comfort and quality services of our hotel. </h2>
<h3 style="text-align: center;">Whether for business or pleasure, the Univers Hotel has everything you need.</h3>
But when I save it become as follows:
<h2>Enjoy the comfort and quality services of our hotel. </h2>
<h3>Whether for business or pleasure, the Univers Hotel has everything you need.</h3>
Do I have to change the CSS file manually ?
Hi Artur
Before adding your inline styling may I suggest switching your editor to the CodeMirror editor (Site -> Global Configuration -> Default Editor -> CodeMirror). Other editors may edit your code when saving which appears to be your issue.
Thank you Ciarán, but I still couldn't solve it. Even I switch editor to the CodeMirror editor, after I save some slashes are added and the problem persist.
Appears you have an issue regarding your 'Magic Quotes' settings on your server. It may be worth checking out the following articles on amending this issue..
http://forum.joomla.org/viewtopic.php?f=706&;t=766329
http://forum.joomla.org/viewtopic.php?f=706&;t=786733
