1. bibbp
  4. Monday, 21 July 2014
Ciaran,
Do you have a Joomla 3 version of Legend?
Peter
Hi Peter
Yes a Joomla 3 version of our Legend template is available... http://www.joomla51.com/joomla-templates/j51-legend
I'm getting this error on the install:
Warning
JInstaller: :Install: Cannot find XML setup file
Extracting the contents of the J51_Legend zipfile says its empty...
Pete
Thank you Pete for bringing this issue to our attention.
If I could ask you to re-download the template the issue should be now amended.
Ciaran,
There are no Joomla 3 files in this latest version.
Peter
:blink: I'll get it right yet!
Could you re-download and check again for me?
I'm getting this error when I install the slideshow:
Warning
Module Install: Another module is already using directory: /home/content/35/11892335/html/http://shameaboutthename.com/mmp_upgrade/modules/mod_briaskISS
It appears the module folder already exists. If the slideshow is not available via your module manager (Extensions -> Module Manager -> New) simply remove this directory (../mmp_upgrade/modules/mod_briaskISS) and re install the module.
All fixed. Thanks again Ciaran.
