1. g.signorino
  3. Saturday, 04 June 2022
Hi, I have seen that for a few days now it is impossible for me to change the style parameters of the j51_layla template. The buttons to access the various blocks have disappeared and what I see is in the attached image. What happened? Dope I can intervene to restore functionality. Thanks and congratulations for your wonderful work. Greetings
Have you made any changes to your template XML since installing? It appears to be missing some required properties?
We have tried updating your template to the latest however we are thrown the following error which indicates some permission issues on your server...
Joomla\CMS\Filesystem\Folder::create: Infinite loop detected.
Warning: Failed to move file: [TMP]/phpltyg8A to /home/upmywli4/domains/http://evangelo.sviluppo.host/public_html[TMP]/j51_layla.zi
I restored the original templateDetails.xml file and the problem was solved! :D
Thanks for your kind reply and congratulations again for the great work you do.
Greeting
Giovanni
