1. maxicom6
  3. Wednesday, 11 December 2024
Ho comprato stamattina il modello J51_layla vedi allegato con l'errore che mi da. Ho un altro template j51_riley e tutto OK
Voglio cambiare il J51_Layla che non va. Massimo Piantoni
I bought the J51_layla model this morning, see attachment with the error it gives me. I have another j51_riley template and everything is OK
I want to change the J51_Layla that doesn't work. Massimo Piantoni
You appear to be attempting to install the Joomla 3 version of the template. I have updated your purchase and download to the Joomla 4 version of the template.
Thank you Mr. Ciaran for your reply. Yes, I probably chose the J3 version of the template by mistake when I purchased J51_layla. Thank you for changing the version to j4 in my Download page of my account that I have already downloaded and installed in my hosting. Everything is ok, perfect. Massimo Piantoni
